Friday, April 28th, 2006 AT 5:49 AM
I just bought an 86 suburban off ebay and I have been told that it has a problem with fuel delivery. I was told that it has a new mechanical fuel pump, but when driven at 65 or so it tends to bogg down. If the gas pedal is released and then applied again, it will work normally again. I was also told that it probably only needs an electric fuel pump. Does this make sense to anyone out here? If so, where would I find the fuel pump, is it an in the tank set up? Any help would be greatly appreciated.
