2001 GMC Yukon FUEL PUMP
REPOMANNC
  • 2001 GMC YUKON
  • V8
  • 132,000 MILES
MY FUEL PUMP WENT OUT AGAIN.
FOUND ANOTHER ONE OUT OF A 4WD 2000 YUKON
WILL IT WORK FOR MY 2WD 2001 YUKON?
Sunday, August 3rd, 2008 AT 3:21 PM
MMPRINCE4000
  • 8,548 POSTS
Depends on the engine. You could call the dealer or autoparts store and check part numbers for both years, if the same then you are OK, if not then don't take a chance.
You would need to know what engine the 2000 had in it.
Monday, August 4th, 2008 AT 7:06 AM
REPOMANNC
Evrything is the same xcept one of the plugs that goes into the fuel pump itself, it was a simple rewire and evrything works. Even used old tank. It was worth the try since I found the pump for 25 bucks. Saved almost $400.00! Thanks
Tuesday, August 5th, 2008 AT 8:14 AM
