1997 GMC Yukon Sport, 198,000 miles. How do I adjust the timing?
Dec 14, 2006 at 10:21 AM
Confirm spark before assuming the timing is off. Ignition timing is controlled by the PCM and is not adjustable. If there is no spark, diagnose the ignition system. If timing is actually off, the timing chain may have slipped and needs replacement.
The owner of a 1997 GMC Yukon asked how to adjust ignition timing after a no-start following fuel-pump work. The vehicle cranks but appears to have no spark, and a shop said the timing was off. The expert explained that the PCM controls ignition and injector timing, so no adjustment is allowed. They advised verifying spark and checking the ignition system first; a slipped timing chain would only be considered if timing is confirmed to be off.
