2007 GMC Yukon starter motor
45,000 MILES • V8 • 2WD • AUTOMATIC
JDAL123
I started my car fine, drove it into the garage. Turned it off. Came back to start the car and nothing happened. Lights work, battery charged. I tried using the electric starter on my key fob, and nothing..I think the starter motor has a problem. Is there a quick fix, I might be able to do to get the car started? Should I disconnect wiring then reconnect. It seems the car is too new to have a starter problem.
Mar 20, 2010 at 2:02 AM
TOOOMANYTOYS
  • 513 POSTS
Have you tried jumping starter at the relay. The relay is located under the hood. Use a fused jumper and jump terminal 30 to terminal 87 and see if it cranks. Also 2007 is it under warranty?
Mar 20, 2010 at 2:22 AM
