Ignition is off, motor noise coming from under
SQV
Noises problem
2002 GMC Yukon 6 cyl Automatic 71,000 miles
Parked my Yukon XL (71,000 miles) on the driveway tonight, and turned off the ignition. For the past 4 hours (plus) there is a motor type noise coming from under the vehicle. Loudest when you put your head under the car, right under the driver's seat. All four tires vibrate slightly when your place your hand on them.....
How do I make the noise stop, short of taking it to the dealer in the morning? Can I pull a fuse? I am afraid it will overheat and catch fire while I am asleep....
Apr 22, 2008 at 4:03 PM
DKVROTTWEILERS
This is because the ABS module is out causing the ABS pump motor to stay on here is a guide to help you fix the problem.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Cheers
Apr 30, 2008 at 8:52 AM
