I started having the low coolant message come on. I checked the coolant before I took it in and it was not low. Temperature was always where it ran about 190 to 200 degrees. Did not come on all the time. Took to a dealer and they said the water pump was leaking a little. Had it replaced. About a week later the coolant light came on. It does not appear to be low and the light after you turn it off and re crank might not come on again for a couple of days. Do I have a bad sensor? If so where is it and how hard to replace.
Jan 27, 2010 at 1:40 AM
