Engine won't start
ERICE
  • 2000 GMC YUKON
Transmission problem V8 Four Wheel Drive Automatic 150000 miles
Installed a rebuilt torque converter, rear main seal, also had the forward clutches in my transmission replaced by a good trans shop.
Everything went back together smooth. Now truck doesn't start. Turns over fine, but will not start. Never had problems with starting before. Check engine light also on, was not on prior to removal of trans. Do not own tester, unsure of what codes being thrown.
Any help appreciated. Is it possible that a wire got nicked, not allowing the engine to start?
Update, found an individual with similar problem. Answer there was to replace the park/neutral safety switch. I could not get the two connectors on this switch to fully "click" into place. Is this a problem?
Monday, November 3rd, 2008 AT 12:47 PM
DENNYP
  • 1,824 POSTS
Yes, you probably have a sticky substance on the connectors that is causing them to not fit properly. You will need to replace the switch and the two connectors. They are available at the dealer. You should also look to see if you have any pinched wires near the top of the bellhousing on the trans.
Wednesday, November 19th, 2008 AT 3:24 PM
