1999 GMC Yukon Daytime running lights dont come on and horn
1999 GMC YUKON
125,000 MILES • V8 • 4WD • AUTOMATIC
SNJINPA
1. I just bought a denali that the daytime running lights dont come on but the dash indicator shows they are on.
2. Horn doesnt work when I try to use it but it does work when triggering alarm.
Any ideas on what to look at for these 2 problems?
May 11, 2009 at 4:36 PM
GSCHALL
  • 10 POSTS
I do not know about the horn problem, but did you check the fuses for the daytime running lights. if so and that was not the problem there are two other items you might want to check and varify are working.
the first is a diode connected to the lead from the wiring harness that sits on the right side of the steering column. if it tests fine then check item two.
item two is a day time running light module that is a small circuit board that in mine sits in a closed free hanging black plastic box to the left of the steerinf cloumn, the bottom of the box opens and you will see the card, it pulls out. i do not know how to test the card since i just swapped mine out with another one to see if it was the problem. it was not my problem so I am still lookikng, most likley moving onto the trun signal high beam switch next. but your problem should be easier to correct then mine.
good luck.
Jun 16, 2009 at 4:54 PM
