Hoe do you reset the 4wheel drive light after it has been serviced?
Monday, November 17th, 2008 AT 6:31 PM
DENNYP
MECHANIC
Disconnect the battery cables and touch them together to discharge the module capacitors. Then, connect the cables. If the light or message is still on, you still have a problem that needs repaired.
