1996 GMC Yukon won't start
RFARTHING
  • 1996 GMC YUKON
  • V8
  • 4WD
  • 190,000 MILES
Starting the truck has been getting progressively worse, and now it won't start at all. Turns over fine. When it did start, it sounded and seemed to perform normally. Should I start with fuel filter replacement?
If the injectors are the problem, I will have to have a professional fix it.
Monday, February 8th, 2010 AT 10:54 AM
TOOOMANYTOYS
  • 513 POSTS
Have you checked the fuel pressure yet? Should be around 40 to 50 psi. Is the check engine light on?
Monday, February 8th, 2010 AT 11:10 AM
JDL
  • 16,098 POSTS
Thanks for the donation. A tune-up wouldn't hurt anything. Also, use a gage and check fuel pressure. Engine cranking, do you have spark at the plugs? You might try some injector cleaner, see if it helps?
If you don't have a fuel pressure gage, some of the national brand autostores used to loan out a fuel pressure gage. There are service bulletins about fuel poppets sticking, GM spider fuel system.
Monday, February 8th, 2010 AT 11:16 AM
