1996 GMC Yukon on start
MECHMAN3870
  • 1996 GMC YUKON
  • V8
  • 4WD
  • 140,000 MILES
1996 gmc yukon will crank but no start replace fuel pump and fuel psi reg help
Sunday, January 31st, 2010 AT 1:56 PM
Did you checked the fuel pressure after you replaced the fuel pump if not do so with fuel pressure gauge designed for your fuel system. If its within specs -Look for ignition spark-
Disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark?
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors-
Sunday, January 31st, 2010 AT 2:05 PM
MECHMAN3870
Ive done that and have spark have noway to check fuel psi no one around here has a gauge
Sunday, January 31st, 2010 AT 2:22 PM
