HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Yukon
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1996 GMC Yukon help
TERESA M. CRAIN
MEMBER
1996 GMC YUKON
Other Category problem
1996 GMC Yukon V8 Four Wheel Drive Automatic 142+ miles
I was driving and the truck just died. I have changed the fuel pump but it still won't start. Can you please help?
Tuesday, January 15th, 2008 AT 5:40 PM
MASTERTECHTIM
MECHANIC
Will it run on carb cleaner or starter fluid.
SPONSORED LINKS
Tuesday, January 15th, 2008 AT 5:41 PM
TERESA M. CRAIN
MEMBER
No it will crank but not trun over
Tuesday, January 15th, 2008 AT 5:45 PM
MASTERTECHTIM
MECHANIC
First you need to check for spark at the spark plugs, if no spark, remove wire from coil and then see if there is spark there. Get back to us.
Tuesday, January 15th, 2008 AT 5:58 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1996 Gmc Yukon On Start
1996 Gmc Yukon Will Crank But No Start Replace Fuel Pump And Fuel Psi Reg Help
Asked by
mechman3870
1996
GMC YUKON
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
2004 Gmc Yukon Fuel Pump Replacement
I Recently Had To Replace My Fuel Pump On My 2004 Gmc Yukon Denali Xl My Truck Was Running Fine The Only Reason That It Needed To Be Changed...
Asked by
cr12078
2004
GMC YUKON
Fuel Pump Went Out, Had It Replaced And Now My Engine...
Service Engine Soon Light Came On After Replacing Fuel Pump For 1999 Gmc Yukon Denali, How Do I Turn It Off Or Is It Another Problem I May...
Asked by
key
1 ANSWER
1999
GMC YUKON
2001 Gmc Yukon Fuel Pump Replacment
Engine Mechanical Problem 2001 Gmc Yukon V8 Four Wheel Drive Automatic 2001 Gmc Yokon Fuel Pump Replacment Can A Carter Vsictrp...
Asked by
Hartlee
2001
GMC YUKON
97 Gmc Yukon Slt 128k, 350. I Am Replacing The In Tank Fuel Pump On My Yukon But Can't Disconnect The Lines To Lower It Enough. Purchased...
Asked by
GMforTM
1 ANSWER
GMC YUKON
VIEW MORE
SPONSORED LINKS
Engine Not Starting
How to fix an engine that wont start
Fuel Pump Pressure Test
Online car repair manuals
