1988 GMC Van oil usage
87,000 MILES • V8 • 2WD • AUTOMATIC
DONALDSALISBURY
I just purchased the van and drove it 500 miles. It used about 2 quarts of oil on the trip and the fuel economy was terrible.
Twice while driving along @ 65-70 mph without accelerating there was a huge puff of black smoke that came out. The tailpipe has heavy carbon buildup but when the engine is first started and as it is driven there is no evidence of smoking. The engine sounds very good and tight and there's no clacking of valves or knocking sounds. There are no oil leaks to be found.
My question is; is the oil going out the exhaust and why. What could be the cause. And could I have damaged the cat or 02 sensors.
Apr 9, 2009 at 12:18 PM
  • 75,988 POSTS
Twice while driving along @ 65-70 mph without accelerating there was a huge puff of black smoke that came out, It indicates too rich of a mixture could be caused by the following:
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
No oil leaks and 2qts of oil for 500 miles is no good-get the engine compression checked could be valves/rings and cylinder wear
Apr 9, 2009 at 12:48 PM
DONALDSALISBURY
Does good compression and high oil usage point toward valve guides. Does low compression mean rings.
Apr 11, 2009 at 1:36 AM
  • 75,988 POSTS
IS IT THE RINGS OR THE VALVES?
If compression is low in one or more cylinders, you can isolate the problem to the valves or rings by squirting a little 30 weight motor oil into the cylinder through the spark plug hole and repeating the compression test. The oil temporarily seals the rings.
If the compression readings are higher the second time around, it means the rings and/or cylinder is worn. No change in the compression readings would tell you the cylinder has a bad valve.
Apr 11, 2009 at 2:36 AM
