Engine not starting
LINDASTEARNS
  • 1997 GMC TRUCK
Engine Mechanical problem V8 Four Wheel Drive Automatic 190, 00 miles
If I drive truck every day it will start, but if I let it set a few days it won't start, it will crank but won't start
Wednesday, July 29th, 2009 AT 8:57 PM
Next time it refuses to start-Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, July 29th, 2009 AT 9:17 PM
