1992 GMC Truck electrical wiring
TJH1LJH2
  • 1992 GMC TRUCK
Electrical problem
1992 GMC Truck V8 Four Wheel Drive Automatic
there is a wire that comes from the battery terminal down pass the starter, then goes up into what I think is the cab firewall. The wire either melted or broke, by the starter. We replaced the positive cable from the battery to the starter. We tried turning on the lights to see if there was power, no lights came on. Then we touched the broken wire from the cab firewall to the starter positive bolt and the lights came on. Then we bought a two ended wire tube ( plastic with metal inside for wiring), connected the broken ends crimped it. Then crimped it at the battery terminal. The truck started, we drove it maybe half a mile then it just died. Opening the hood it smelled like plastic burning, any idea what this wire could be called or what to look for next in troubbleshooting whats wrong?
Thursday, January 8th, 2009 AT 8:13 PM
MICKEY-D
  • 304 POSTS
The wire you describe is called a fusible link. It supplies 12volts to the entire fuse block. Check for a pinched wire in the harness where you found the burnt wires by the firewall, and check the wires to, and at the alternator.
Wednesday, January 6th, 2010 AT 6:53 PM
