1993 GMC Truck GMC Z71 Starts then shuts off after a few SE
HUDDLE01
  • 1993 GMC TRUCK
  • V8
  • 4WD
  • 250,000 MILES
Been having this issue over a week now. Truck starts perfect no hesitation or anything. Idles great then after 5 or so seconds it just goes off (like I turned the key off, no sputtering or anything) After I start it and go through this anywhere from 2 to 6 times it finally stays running and once it does I can drive it anywhere and it runs great. After I turn it off, goes through the same ordeal again until its decides one random time not to shut off then I am on the road again. Any thoughts?
Thanks and god bless!
Friday, July 10th, 2009 AT 3:13 PM
  • 109,885 POSTS
Has the check engine light come on? Have you noiced the security light staying on or flashing when this happens?
Friday, July 10th, 2009 AT 11:19 PM
HUDDLE01
No, no check engine through any of this. Not sure what the security light is.I have no alarm if thats what it is.
Friday, July 10th, 2009 AT 11:53 PM
  • 109,885 POSTS
If you turn the key to he run position without starting the engine, is there a light that comes on that says security? Also, have you been able to identify if you are loosing spark or fuel pressure when it dies? At this point I question the ignition module or the fuel pump. If the module is bad, you will loose spark. With a bad pump, fuel pressure will drop.
Saturday, July 11th, 2009 AT 8:07 PM
HUDDLE01
I am assuming that its fuel, just judging from how its acting. Its gotten very difficult to start, once its starts it runs good still until I turn it off again. I can try starter fluid and if it runs on it the spark is good correct? I will do that tomorrow. I ran a power wire straight to the pump from a key controlled source, when I turn the key sometimes I hear the pump run and sometimes I dont, others it will run for a few seconds then stop. With constant power shouldnt I hear it running all the time?
Saturday, July 11th, 2009 AT 8:53 PM
  • 109,885 POSTS
If it runs on starting fluid, it is getting spark. Also, if you ran power to the pump, if will run all of the time. NOTE: Sometimes the pump could loose pressure from a leak which can cause a hard start. If you check fuel pressure, also check how quickly the pressure drops when you turn the key off. It should hold pressure for several minutes.
Saturday, July 11th, 2009 AT 9:18 PM
