1998 GMC Truck wont keep running
1998 GMC TRUCK
KEITHFIRE
Engine Performance problem
1998 GMC Truck V8 Four Wheel Drive Automatic
my truck starts and runs for a few seconds and then quits, if i feed it with gas it will continue to run i have replaced the fuel filter and fuel pump but it continues to only run for a few seconds any suggestions
Mar 3, 2010 at 1:42 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure, as it should be at least 40p.s.i. to run the truck. BUT that particular year had a problem with the harness going to the fuel pump. Delco sell s a fuel pupmp with the 12" of harness that you neeed to put in otherwise if you insatall a nother pump it will fail again....
Apr 5, 2010 at 12:45 PM
