1990 GMC Truck won't restart
MOCARPENTER
  • 1990 GMC TRUCK
  • V8
  • 4WD
  • MANUAL
  • 120,000 MILES
It has only slight hesitation starting first thing in the morning but after warming up it won't restart until engine cools. The engine will crank just fine but won't turn over. If I leave it still at work all day then it restarts just fine. I just can't move it within a couple hours. I've put heet, fuel injector cleaners, and new gas in the tank. I've replaced the fuel filter, spark plugs, and spark plug wires. Someone told me try the distributor.
Friday, February 19th, 2010 AT 7:22 AM
2CARPRO JACK
  • 11,533 POSTS
Could be one of the electronic items in the distributor(pick-up coil or ignition module). Have you checked to see if it has spark when it wont start?
Friday, February 19th, 2010 AT 7:41 AM
MOCARPENTER
How do I check for spark?
Friday, February 19th, 2010 AT 9:42 AM
2CARPRO JACK
  • 11,533 POSTS
Use a spark tester so you dont get shocked. They are cheap and available at auto parts stores. Test for spark out of coil and out of distributor
Friday, February 19th, 2010 AT 10:28 AM
