Is the check engine light on? I need a compression test done on this engine, remove all plugs and test this way, note results in each cylinder.
https://www.2carpros.com/dia/how_to_check_compression.htm
And a fuel pressure test wouldnt hurt either, but 16hg of vac is still too low, so either a valve spring, or severe vacuum leak exists...Still have that vacuum gauge?
https://www.2carpros.com/dia/test_engine_vacuum.htm
Then find vac leak like this. Get a can of spray Throttle body cleaner, start the car and spray around, pay attention to vacuum lines and manifold, if the idle changes, you found a leak. You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If it has a vacuum power brake booster, disconnect and plug the hose and test vacuum with the gauge...Booster diaphram may have a leak too.
A good source on reading the gauge.
http://findarticles.com/p/articles/mi_qa3828/is_200108/ai_n8978956/
Thursday, January 14th, 2010 AT 1:33 PM
