1999 GMC Suburban timing chain
1999 GMC SUBURBAN
145,346 MILES • V8 • 4WD • AUTOMATIC
MACKLAREN
when to chainge the timing chain I own a 1999
gmc suburban with 145346 miles
Jan 2, 2009 at 11:39 PM
  • 31,937 POSTS
Hi there,
There is no set time to replace the timing chain, what you lay when you turn the crank a bit (remove the plugs first) backwards and forward, there is no tensioner so with excessive play the valve timing will be out a tittle as well, you should replace the chain and both gears as well, they will be sold as a set.
Mark (mhpautos)
Jan 3, 2009 at 3:03 AM
