Starting problem
MHEROIS
  • GMC SONOMA
1999 gmc sonoma 2.2 4 cylinder 83k
i am having an issue probably about every 10 starts. I will turn the key and no warning lights or noises will come on and then I try to crank the engine and all I get is a clicking noise then it sounds like its sucking air then another click and it just stops, then I start it fine with no problems. But it only happens about every 10 starts. I just cleaned my plugs and checked all my wires to make sure there not loose. Any help would be great
Thursday, November 29th, 2007 AT 5:37 AM
BLACKOP555
  • 10,371 POSTS
Sounds to me that your ignition switch is starting to go, take it out and have it tested.
Thursday, November 29th, 2007 AT 7:02 AM
MHEROIS
Alright thats the second time I have heard ignition switch, thanks for the help!
Thursday, November 29th, 2007 AT 4:19 PM
BLACKOP555
  • 10,371 POSTS
No problem. Good luck! Hope you find out whats wrong.
Thursday, November 29th, 2007 AT 6:56 PM
