1993 GMC Sonoma Squealing While Moving
SUSAN SUMMERS
I have a 93 GMC sonoma truck,100,000 miles, 3.5 ? engine, I think. I have a high pitched squealing noise when the truck is moving. When the brakes are applied it stops. Could this be the brake indicators?
Is there a ball park figure as to how much labor alone should be for a job like that?
Apr 12, 2007 at 8:07 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, sounds like the "screamers". Depends on what parts are used, anywhere form 130.00 to upwards of 200.00
Apr 16, 2007 at 1:11 AM
Suggested Repair
The squeal that stops when the brakes are applied is consistent with brake wear indicators (screamers). Have the brake pads inspected and replaced as needed; parts-dependent cost was estimated at about $130 to $200.
Conversation Summary
A 1993 GMC Sonoma with about 100,000 miles makes a high-pitched squeal while moving that stops when the brakes are applied. The owner asked whether brake wear indicators were the cause and what labor might cost. The expert agreed it sounded like the wear indicators and estimated roughly $130 to $200 depending on the parts used.
