96 gmc sonoma ac/heater controls do not work
GMCSONOMA
I have a 96 gmc sonoma with 189k miles, and the swith contorl for the heater and ac goes on but it only blows out of the defrosters and floorboards. both the heat and a/c work fine but the controls do not change where the vents blow out of. thanks for the help.
Jun 20, 2007 at 8:55 AM
DANIMALGMC
  • 33 POSTS
It sounds like you lost a vacuum hose under the dash somewhere. The vacuum controls the mechanism that controls the air flow selection.
You might be able to here the vacuum.
And if you;'re a smoker, blow smoke under the dash and follow it.
Or bad control valve
Jun 25, 2007 at 3:18 AM
GMCSONOMA
I'll try that, thanks for the help, I hope it works, its kind of annoying.
Jun 25, 2007 at 5:31 AM
