HVAC Vent controls
102,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIM2002
I am having trouble with the Defrost/Feet/Vent/AC control. It is a 2002 GMC Sonoma with ZR5 Package. When I go to put the air to blow on my feet or defrost nothing happens. I can turn the switch over to the AC mode and it will start blowing cold air. It still comes out the 4 vents (face). It only blows out of the 4 vents that point at my face. It will switch to AC and the AC works fine but it still only comes out of the 4 vents on the dash by my face. I use to be able to hear it switch and I no longer even hear it trying to switch.
Any ideas as to what is wrong?
Feb 25, 2009 at 12:52 AM
SERPENTRACER
  • 34 POSTS
There is a mode blend door actuator that sounds like it is not working correctly here is a guide to help you fix the problem.
Feb 27, 2009 at 11:22 PM
WIBRACKENS
  • 0 POST
Thank you for this post I had this problem and had to replace the mode actuator cost me $64.00 all fixed I love this site.
Nov 12, 2019 at 3:26 AM
SLV123
i am getting all the heat through the top vents OR the defrost and it wont blow out on the floor! can you help?
Nov 12, 2019 at 3:27 AM (Merged)
ROBBIET
  • 8 POSTS
sounds like you likely need to check your vacuum hoses for cracks and breaks. Can't tell u where they all are, but you'll have to poke around unless the dealer can give you a schematic printout of where they run.
TROYLEBLANC
I have a 2000 GMC Sonoma, and i can't get any heat, but the heater cord is not plugged. Wondering if something turns it from hot to cold.
  • 75,988 POSTS
Check the thermostat if okay inspect the air blend door if its in the heat position
TROYLEBLANC
how do find that
