2001 GMC Sonoma VIBRATION
51,000 MILES • 6 CYL • 4WD • AUTOMATIC
EAMES88
I have noticeable vibration on the driver's side and noise when on rough roads or at 62+ mph on the highway. 2 years ago had an accident, scraped full passenger side of truck against telephone pole. According to the repair shop the damage was mostly superficial as mirror was torn off and front head light damaged and scrapes from front to back. Largest dent was behind rear wheel well, when I jerked the wheel. Husband insists this is alignment issue caused from accident, 3rd party repair shop says alignment is fine and they rebalance the tires and it seems fine. However this vehicle is only driven about one a week, sometimes less. Any ideas on the source of this vibration and it sounds like a rattle in the passenger door under same conditions noted above. Final comment, I noticed the passenger seat shaking while I was driving on the highway this morning even at 45 mph. Thank you.
May 4, 2010 at 1:56 AM
CARADIODOC
  • 34,414 POSTS
Hi eames88. Welcome to the forum. Alignment issues cause tire wear patterns, a crooked steering wheel, and / or pulling to one side when you let go of the steering wheel. Except for very rare and unusual circumstances, it will not cause a vibration and even then, worn parts are involved.
Out-of-balance tires, of course, are the most common causes of vibration, but a bent wheel, bent hub, and warped brake rotor can also cause this symptom. If the brake rotor is warped, you should also feel it in the steering wheel during braking if the caliper is sticking to its mount and is not able to slide back and forth freely. A tight universal joint on the front axle, between the upper and lower ball joints, will cause a vibration too although it shouldn't be so speed-specific.
To find out if this is tire / wheel-related, your mechanic should run the vehicle on a hoist, in gear, and in 4wd, then place a dial indicator against the lip of each wheel to check for sideways runout. Anything over around .040" should be investigated. Remove the wheel with excessive runout and perform the same test on the brake rotor after the lug nuts are reinstalled. If the vibration began after a front wheel was removed, it is possible for rust or scale to break off the rotor and get stuck between the rotor and hub. That will make it wobble and show up with the dial indicator.
If there is no excessive runout, switch the two tires from one side, front to rear, then drive it to see if there is a change. If not, switch the two tires from the other side. If switching one pair front to rear makes the problem change, inspect the tire that was moved to the rear for a bent wheel or broken belt in the tire. Broken belts are more common on high-mileage tires, and bent wheels are more common than you would expect.
caradiodoc
May 4, 2010 at 6:44 AM
