1997 GMC Sonoma Same old Headlight song!
11,500 MILES • 6 CYL • 2WD • AUTOMATIC
ZIONRIDER2K
It all started on a cross country trip, when my headlights no workie-workie, but DRL's and brights worked just dandy. So everybody got the high-beams for about 3mos. (I know, yeah, I'm that guy) but now my brights stopped working, check mating me into some dreaded mechanic work. Tail lights and DRL's still working so I think I've narrowed it down to a broken wire, bad relay, corroded switch or a blown fuse! Just thought that there may be a couple of usual suspects for this problem that I can handle so I can get back to watching football. Thanks and I'll be checking fuses in the mean time.
Oct 23, 2008 at 11:26 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:652099d8bd="zionrider2k@yahoo.com"]Electrical problem
1997 GMC Sonoma 6 cyl Two Wheel Drive Automatic 115,00 miles
It all started on a cross country trip, when my headlights no workie-workie, but DRL's and brights worked just dandy. So everybody got the high-beams for about 3mos. (I know, yeah, I'm that guy) but now my brights stopped working, check mating me into some dreaded mechanic work. Tail lights and DRL's still working so I think I've narrowed it down to a broken wire, bad relay, corroded switch or a blown fuse! Just thought that there may be a couple of usual suspects for this problem that I can handle so I can get back to watching football. Thanks and I'll be checking fuses in the mean time.[/quote:652099d8bd]
Ok, first what have you checked.
Did you check the sockets for power.
Have you checked sockets for ground.
I ask because you mention nothing about testing or what you have done to determine a possible broken wire.
Oct 23, 2008 at 2:27 PM
