1993 GMC Sierra Starter Runs Without Key
JPETTITT
I have a 93 gmc Sierra with 92,000 miles, 350 5.7 liter engine. I recetly bought a new head unit/radio and was going to install it. So I unplugged the negative terminal from the battery. Then cut the existing wires to the old radio and cassette player. Then I hooked up the new radio and hooked up the negative terminal to the battery and the truck starts up and the starter keeps going, all without the key in it. PLEASE HELP!!!!
Aug 20, 2007 at 11:12 AM
  • 75,988 POSTS
[quote:dbb0c71656="jpettitt"]Hi,
I have a 93 gmc Sierra with 92,000 miles, 350 5.7 liter engine. I recetly bought a new head unit/radio and was going to install it. So I unplugged the negative terminal from the battery. Then cut the existing wires to the old radio and cassette player. Then I hooked up the new radio and hooked up the negative terminal to the battery and the truck starts up and the starter keeps going, all without the key in it. PLEASE HELP!!!![/quote:dbb0c71656]
all without the key in it. PLEASE HELP!!!! The only way for this to happen is your power input to the switch is shorted to the starter circuit from the switch or the wiring.
Aug 20, 2007 at 11:46 AM
Suggested Repair
Inspect the ignition switch and related wiring for a short between the switch power input and the starter circuit, including radio wires that were cut and reconnected during the head-unit install.
Conversation Summary
The owner of a 1993 GMC Sierra disconnected the battery, cut the factory radio wires, and installed a new head unit. After reconnecting the battery, the starter engaged and kept cranking with the key out. The expert said the ignition-switch power input is shorted to the starter circuit at the switch or in the wiring.
