You will not find the PCB relays as the are Printed Circuit Board relays which means that they are built right into the fuse block. The BCM is behind the knee bolster on the left side under the column. You may want to check see if the park switch in the wiper cover has a proper ground. The black white wire coming out of the wiper cover. You can relocate the ground to somewhere on the firewall.
SPONSORED LINKS
Wednesday, November 3rd, 2010 AT 8:34 PM
