How's your oil level? Might want to test out the fuel pump/oil sending unit-it powers the fuel pump constantly after the engine starts up. Could be losing oil pressure and the FPOSU is cutting out-not closing the circuit an intermittently shutting down the fuel pump.
When you replace the fuel pump did you check the fuel pressure?
SPONSORED LINKS
Monday, February 11th, 2008 AT 3:53 AM
