The driver side door will open/close and lock from the inside but will not open from the outside. I removed the interior panel and found a "L" shaped rod laying loose. The dimensions are about 5" by 3"and the short end of the rod has been dipped in a red rubber coating. I cannot see where this goes. The rod is about an eighth of an inch in diameter. Can you help and is there an exploded view of the lock system on line where I can see a pictorial of the lock system? Help. Thanks
SPONSORED LINKS
Thursday, April 16th, 2009 AT 8:05 PM
