1998 GMC Sierra Door
192,000 MILES • V8 • 2WD • AUTOMATIC
STEINBACH2008
The driver's door will not open from the inside using the door handle. The door can be opened using the door handle on the outside of the truck. The doors are on a remote entry system as well and it still works. How can this be fixed? Thanks.
May 26, 2008 at 9:19 AM
MERLIN2021
  • 17,250 POSTS
you need to remove the trim panel and inside the door, there are steel rods that connec the handles and locks, the one for the inside handle has popped off, it may need a new retaining clip at the end.
May 26, 2008 at 10:26 AM
