Yes the fuel pressure is normal, should be 60-66psi. It is normal for the pressure to hold with the key off. A rule of thumb is it should not bleed down any more than 5psi every 20 min. So this is normal and it shows the injectors are not bleeding down. As far as checking things these are some things to check:A loose CMP sensor causing a variance in the sensor signal
"Â Excessive free play in the timing chain and gear assembly
"Â Incorrectly installed distributor - 1 tooth off in either advance or retard positions
"Â A loose distributor rotor on the distributor shaft
"Â A loose or missing distributor hold down bolt
was the distrubutor ever taken out? A bad crankshaft pos sensor can cause this. I've also had a few with the distributor broken and loose inside the shaft. Might want to pull the cap and move the rotor back/fourth and see if the dis moves excessively. Found a couple broken distributors. Post back with what you find and will advise from there.
SPONSORED LINKS
Saturday, January 3rd, 2009 AT 3:23 PM
