1990 GMC Sierra clutch
ANGIE GRIMM
Transmission problem
1990 GMC Sierra V8 Manual 175000 miles
clutch not working. replaced master cylinder and slave cylinder and lines but can't get fluid through lines and no pedal
Nov 8, 2008 at 10:08 AM
  • 31,937 POSTS
Hi there,
bleed the master cylinder first, take of the pipe and press pedal, have someone block out let with a finger and release pedal, don't remove the finger till the pedal is fully up, do this 3-4 times until fluid ids flowing, if it wont the master is faulty, if you get fluid , re attach the line and complete the bleeding at the slave.
mark (mhpautos)
Nov 8, 2008 at 10:14 AM
