2000 GMC Safari Miss on Cylinder #4
2000 GMC SAFARI
110,000 MILES • 6 CYL • FWD • AUTOMATIC
WARIK
The other night I was driving home and the throtle control cabel that connect from the accelerator pedal to the engine broke in half. I had that replaced today, and now when i drive the car it runs horrible. The engine is clearly getting a mis-fire. I had the engine code run and it is showing a miss on Cylinder number 4.
I was thinking that maybe when they replaced that throtle control cable they might have screwed up the sparkplug cable going to theat cylinder?
Jun 19, 2009 at 12:13 PM
Misfire @ no.4 should lead you to check that cylinder's sparkplug/compression/injector
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jun 19, 2009 at 12:16 PM
WARIK
The thing it is has never had a problem with this unitl this throtle cable broke last night. It was 30 for the cable and 90 for the labor to get that fixed which is not horrible, but when I got in it, it was running just horrible.
They are going to take a look monday and I am hoping that they just screwed up a spark plug wire or maybe it needs a new plug. Sadly I am not sure if it is somthing the shop did when replacing that cable or if it is something else not related. Anyway, I will ask them to check those things. Thank you!
Jun 19, 2009 at 2:41 PM
