1987 Chevy Pickup Water in Oil
GMC
TWOCAMAROBILL
1987 chevy p/u 1/2 ton 305 v/8 ,i"ve got the milkly looking oil under the oil filler cap but not on the dip stick.do you thank intake or head gasket or what ,Thanks :?:
Feb 6, 2006 at 5:28 AM
MVANNESSJR
  • 223 POSTS
Do an oil change and examine the oil. Let us know how that looks.
Feb 6, 2006 at 7:16 PM
TWOCAMAROBILL
[quote:4529620585="mvannessjr"]Do an oil change and examine t he oi l. Let us know how that looks.[/quote:4529620585] sorry but i failed to let you know about the water lost .i can fill the radiator and overflow bottle and within 100 miles the bottle is empty. have not seen coolant on the ground or outside the engine .
Feb 7, 2006 at 12:11 PM
MVANNESSJR
  • 223 POSTS
Great... :shock:
Classic blown head gasket. Not sure how much damage has been done or if the truck is worth fixing at this point, it's up to you.
Feb 7, 2006 at 12:33 PM
Suggested Repair
Treat this as a blown head gasket. Coolant is being lost with no external leak, and milky residue under the oil filler cap supports internal coolant mixing. Assess how much engine damage has occurred and decide whether the truck is worth repairing before proceeding.
Conversation Summary
The owner of a 1987 Chevy 1/2-ton pickup with a 305 V8 reported milky-looking oil under the filler cap but not on the dipstick, and later added that the radiator and overflow bottle empty within about 100 miles with no coolant visible on the ground or outside the engine. The expert identified the symptoms as a classic blown head gasket and said the extent of damage and whether the truck is worth fixing are uncertain.
