1991 Buick Park Avenue Turn Signals Dead
GMC
STEVO69
1991 buick park ave,119,300miles.turn signals don't work at all.they don't come on or nothing.worked fine the day before.i replaced all three silver flash fuses.and still nothing.checked all regular fuses & their fine.now what??
stevo
Apr 21, 2006 at 10:10 AM
LOSONE
  • 1,616 POSTS
Replace the flasher unit. If it doesn't help it is probably the turn signal sw. They are a medium failure item and dealer only for about $50.00
Apr 21, 2006 at 10:54 AM
Suggested Repair
Replace the flasher unit. If the turn signals still do not work, the turn signal switch is the likely cause and is typically a dealer-only part.
Conversation Summary
The owner of a 1991 Buick Park Avenue reported that the turn signals stopped working completely after working the day before. All three flasher fuses and the regular fuses were checked and found fine. The expert advised replacing the flasher unit, and if that does not help, replacing the turn signal switch.
