1996 Pontiac Grand Am Overdrive Shake
GMC
MEANSTREET5150
I noticed today that (especially when driving higher speeds and on the freeway) that my car seems to miss... It's really strange and I don't know if it is tranny slippage or not.
When I accellerate gradually, I have no problems and it's smooth... But when I put the car in overdrive or I accellerate faster, the car shakes and feels like it's missing or grabbing. Yet, when I accellerate gradually, this problem does not happen. It usually starts (or perhaps becomes noticable) around 55 miles an hour and 65 miles an hour.
It's NOT like I can't switch gears though, like I said, when I gradually or smoothly accellerate all things are fine, I only really notice it when I'm in overdrive or GOING UP HILLS.
any ideas? God Bless
Ian
Apr 1, 2006 at 7:43 PM
LOSONE
  • 1,616 POSTS
What kind of car? It sounds like a Ford overdrive problem as they do shudder and it seems like an engine misfire when they are ready to come apart; expensive repair--Let me know
Apr 2, 2006 at 4:06 AM
MEANSTREET5150
I apologize, it is a pontiac Grand Am... 1996.
Like i said, when I accellerate gradually the car has no problem and runs smooth. But when I'm going up hill and I have to press the gas more, or when I'm on the freeway and I put the car in overdrive it feels like it grabs or misses. This happens around 55 miles and 65 an hour and up.
God Bless
Ian
Apr 2, 2006 at 5:43 AM
LOSONE
  • 1,616 POSTS
What engine do you have and how many miles?
Pull the tranny dip stick while hot and smell the oil.
If it smells burnt and is a very dark brown then all probabliity it is the tranny
Before I would blame the tranny I probably would change the plugs.
Apr 2, 2006 at 5:57 AM
MEANSTREET5150
[quote:e1cda0abc1="losone"]What engine do you have and how many miles?
Before I would blame the tranny I probably would change the plugs.[/quote:e1cda0abc1]
engine is 3.1 and has 186,000 miles on it.
so you think it could be the spark plugs then?
thank you so much
Apr 2, 2006 at 6:04 AM
Suggested Repair
With the transmission hot, check the fluid for a burnt smell and very dark brown color. Change the spark plugs before concluding the transmission is at fault.
Conversation Summary
The owner of a 1996 Pontiac Grand Am with a 3.1 engine and 186,000 miles reported shaking or a grabbing or missing feeling in overdrive, under harder acceleration, and on hills around 55-65 mph, while gradual acceleration felt smooth. The expert advised checking hot transmission fluid for a burnt smell and dark color, and changing the spark plugs before blaming the transmission.
