1995 Chevy Cavalier Stalls in Reverse
GMC
CANCER1
I have an 1995 chevy cavalier 156000 miles ,sometimes when I put thr car in reverse it stalls then when it does get moving it makes kind of a rumbling noise, could it be the transmission going bad ?
Apr 14, 2006 at 2:29 AM
LOSONE
  • 1,616 POSTS
With that many miles you are already due for a new tranny. You could chance a service and se if that helps but I doubt it. Good Luck
Apr 14, 2006 at 2:32 AM
Suggested Repair
At this mileage the transmission is likely worn out. A fluid service can be tried, but replacement is the more probable fix.
Conversation Summary
The owner of a 1995 Chevy Cavalier with 156,000 miles says it sometimes stalls when shifted into reverse and then makes a rumbling noise once moving, and asks whether the transmission is failing. The expert says the transmission is already due for replacement at that mileage and that a service could be tried but is unlikely to help.
