1997 Chevy Cavalier Dies While Driving
CHICKYBOOM86
I have a 1997 Chevy Cavalier, with about 100,600 miles on it. I was driving down the highway and all of a sudden my car started to slow down. I was unable to press on the gas to feed the car more gas because it wouldn't go down. All of my gages went down, and all of my service lights came on,and my car started to slow down. I turned my car off and turned it back on, but it wouldn't click over to start. I had gotten it fixed, so I thought. They changed some broken wires and replaced a couple fuses, and thought that that's what the problem was, but to only find out later that that wasn't the problem. if you have any ideas that will help to figure out the problem, please let me know. Thank You
Feb 21, 2006 at 1:28 PM
HB19572
I think it is your alternator, because if your car just suddenly quit, and your gages went down. The alternator is not working because it is not charging the battery. But if you don't think it is the alternator, you could have it checked at a auto parts place or garage. I had mine checked the other day, when I took it out. I took it to Checker Auto Parts and had them "spin" it. And it failed the test so I knew what it was.
Feb 22, 2006 at 1:13 PM
PEPPERMRJ
  • 1,158 POSTS
Yes, charge the battery and then have the battery and alternator tested. A lot of the larger chain stores here in the US will provide these services free of charge.
Be sure and check out the prices and quality
Good luck and let us know. :)
Feb 23, 2006 at 5:01 AM
Suggested Repair
Charge the battery, then have both the battery and alternator tested. Many larger auto parts chains offer this testing at no charge. Compare repair prices and part quality before replacing anything.
Conversation Summary
A 1997 Chevy Cavalier with about 100,600 miles lost power on the highway: gauges dropped, warning lights came on, the accelerator would not respond, and the car would not crank after being shut off. Earlier wire and fuse repairs did not fix it. A reply suggested a failed alternator that was no longer charging the battery. The expert agreed to charge the battery and have both the battery and alternator tested, noting that many chain stores offer free testing and advising the owner to compare price and quality.
