1998 Cavalier:Replacing Alternator:Need help w/tensioner
WALNO1
I am trying to replace my alternator. As far as I know, I need to loosen the belt tensioner to allow slack in the belt, so I can pull it of the pulleys.
My problem is I have limited access to the tensioner. I cannot get a ratchet in there because the ratchet is too thick. I have bought a special serpentine belt wrench, but it is so long I cannot move it in any direction w/o bumping other brackets.
Can it be possible to change the alternator just by unbolting it and manually removing the belt?
Also when I put the new one in, will I be able to put the belt back on manually?
Jun 9, 2007 at 11:59 AM
WALNO1
NVM; Problem fixed.
I took the alternator off just by unbolting it, naturally the belt slid right off. My concern was putting the new one on.
Of course when I put the new one on, I had no slack in the belt. With limited access to my belt tensioner, I managed to get my belt tensioner tool in there, but still could not get enough leverage.
After staring at this thing for awhile, I realized I could just push down on the tensioner as opposed to turning the tensioner. Once I realized this, I pushed down more than enough I then just slipped the belt on.
Hope this might help someone else.
Jun 9, 2007 at 5:25 PM
