security lights come on by themselves
GMC
79CADY
security lights come on by themselves in my 79 cadillac.The headlights and taillights flash at any time of the day or night,The security system was disabled by the former owner so the horn would not sound.I know nothing about security systems and need to know how to disable the light problem before I end up with a drained battery.A wiring diagram would be a great help,
Jan 14, 2006 at 10:52 AM
MER449S
  • 6 POSTS
The wiring to the horm was probably cut but the alarm system is probably still intact. Sometimes you can find the brain to the security system behind the rear defrost button. If the button acts somewhat odd, not quite sititng on the right command but somehow working anyway suspect the car alarm control panel has been hidden there. Unplug the brain and plug the wire to the rear defrost back in so the rear defrost will continue to work. That should do much to dismantle your alarm. This may not work for all vehicles but for some. Try it if you like.
Jan 28, 2006 at 6:23 PM
