Engine light
THEJTRAIN
  • GMC
I have a 91 chev corsica with 98000 miles on it. The engine light started coming on periodically last week. When it does, the speedometer stops working and the car hesitates for a second then drives normally. Also when the light is on, the engine idles either too high or low, and the exhaust smells like rotten eggs. Remember the light isn't on all the time, and the problems only occur when it is on. Any suggestions?
Josh
Sunday, April 23rd, 2006 AT 2:28 PM
THEJTRAIN
No guesses even? I'm kinda stumped. Changed O2 sensor, didn't work. And was thinking pcv valve. Help PLEASE!
Thursday, April 27th, 2006 AT 5:17 PM
SWEET TART
  • 15 POSTS
If your check engine light is coming on the car should have set a code, have a mechanic pull the code, it may save you from replacing parts you don't need. There are several different things that could cause this problem. GOOD LUCK
Thursday, April 27th, 2006 AT 9:24 PM
