Replacing ignition in a 1994 Delta 88
1994 GMC
OLDS
I have a 1994 Delta 88 that turns over but won't start. Its in a friends pro shop and has been checked over with the expensive scan. We've replaced the module in the tran, the coil pack module, the coils and still no spark. We think its the ignition switch or the computer. Want to change the ignition switch first.
Thank you
Dec 21, 2006 at 6:18 PM
GARFIELD
  • 197 POSTS
Are you getting 12 volts to the ignition module?
Dec 22, 2006 at 10:16 PM
OLDS
I'm not sure, the mechanic said the next thing to try was replacing the ignition switch. Currently we have it down at an alarm shop that is removing an old alarm to make sure that isn't the problem. I was just preparing for the next move if the alarm turns out to not be the problem.
Should I check at the ignition switch/ moduce for twelve volts??
Dec 23, 2006 at 5:06 AM
