Pontiac Sunbird 2.0 4cyl. Code 15
1915 GMC
SWITZEE
I have a Pontiac Sunbird 2.0 4 cyl with 132K.
While running for approx. 2 minutes, the cooling fans both come on, along with the check engine light.
I pulled codes, and found a "code 15" Low Coolent Temp
I've replaced both coolent temp sensors ( The one in the head, and the one in the thermostat housing ).
I've also replaced the thermostat, and the ECU, too.
What am I missing, here?
Thanks much,
S.
May 22, 2006 at 8:15 AM
LEFORD18
i replaced the ECU,and fan relay,and Temp switch. Fan would not come on. Had to replace temp switch again and it worked. Mine is a 1994 with only one fan. The temp switch sends signal to Computer and then through relay on mine. le ford
May 23, 2006 at 5:49 AM
