1994 Chevrolet S-10 Locked Rear Brake
GMC
SYNCRAIT
  • 235 POSTS
Im looking into buying a 1994 S-10 but the guy says it has a locked up rear brake and says he tried freeing it by towing it and said that didnt work.... i was wondering if you have any other suggestions for freeing it up i believe its drums in the back but i havent had any time to look at the truck
May 3, 2006 at 10:06 AM
LOSONE
  • 1,616 POSTS
Don't always believe what a person tells you that is trying to sell a truck. It could be a brake or it could be a rear end or any part of the drive line. Let a pro look at it.
May 3, 2006 at 10:12 AM
SYNCRAIT
  • 235 POSTS
ok dually noted, now just the benefit of the doubt. if it was just seized how would i go about it, also is there also a fool proof way to determine that it would a bad rearend and not just a lock up
May 3, 2006 at 10:40 AM
BURRBRIAN
  • 158 POSTS
You know, if he wants to sell the truck that bad he would get the drum off for you and let you check things out from there. If you want to take it off yourself adjust brakes all the way in and take a hammer, beat drum some and see if you can loosen it up so you can get it to slip off. Once you get the drum off pick up rear end of truck and see if wheels will turn then. If not the rear end is probably locked up and you should look elsewhere. Just my opinion but if he told me that I would have to wonder about the rest of the truck. Good luck and don't get stuck!!
May 3, 2006 at 12:22 PM
Suggested Repair
Do not rely on the seller's diagnosis. Retract the rear drum brake adjusters fully, tap the drum with a hammer to free it, and remove it. Then raise the rear and check whether the wheels turn. If they do not, the rear axle or driveline may be locked rather than just the brakes. Have a professional inspect the truck before buying.
Conversation Summary
A buyer considering a 1994 S-10 was told the rear brake was locked and that towing did not free it. Experts warned the problem could instead be the rear end or driveline and advised verifying it before purchase. Suggested checks were retracting the adjusters, freeing and removing the drum, then raising the rear to see if the wheels turn. If they still will not turn, the rear end is likely locked and the buyer should look elsewhere.
