1999 GMC Sierra Headlights Stay On
GMC
DEBHICKS
1999 GMC sieraa truck. 105,000 miles. The headlights stay on when the ignition key is on. Not the DRLs
Jul 31, 2006 at 8:58 AM
MIKEYBDMAN
  • 623 POSTS
[quote:3dbad17c40="debhicks"]1999 GMC sieraa truck. 105,000 miles. The headlights stay on when the ignition key is on. Not the DRLs[/quote:3dbad17c40]
Sounds like something is keeping the Headlamp relay closed. Could be a bad relay stuck closed. The two inputs are from the Body control Module, but that should loose power when the ignition switch is off. The other is the Headlamp and Panel Dimmer switch. This is always hot. Remove your relay from the Underhood Bussed Electricl centor, and test it out. This diagram is hard to read, but the pin numbers should be 30, 35, 36, and 37? Anyway, pin 30 and 37 should be open with the relay out. If they show continuity, then the relay is stuck closed and needs to be replaced.
Now, if that leg of the relay is open, then check pin 35 for power. If it has power, I would suspect the light switch in the truck as being bad keeping the relay powered.
Good luck and let us know what fixed it.
Jul 31, 2006 at 9:10 AM
DEBHICKS
I took out the relay and replaced it with one tha I know works. It didn't fix it. The pin nos. are something like 30,85,87 etc.
Aug 1, 2006 at 2:39 PM
MIKEYBDMAN
  • 623 POSTS
[quote:9a4e46b6a5="debhicks"]I took out the relay and replaced it with one tha I know works. It didn't fix it. The pin nos. are something like 30,85,87 etc.[/quote:9a4e46b6a5]
I would check pin 85 for power. If you have a volt meter, touch the pin 85 with the positive lead, and the negative lead to a known ground like the frame. If you are showing power, like 12 volts, then I would suspect the light switch in the cab to be the problem.
If you dont have a meter, most auto parts stores sell a light tester that will light up if 12 volts is applied. Touc the positive of the light meter to the pin, and the negative to a ground.
I know the older fords usta have problems with their light switch turning the lights off while you were driving, but I guess GM does the opposite. lol
Aug 1, 2006 at 4:17 PM
Suggested Repair
A known-good headlamp relay did not stop the headlights from staying on with the key on. Check relay pin 85 for 12 volts to ground; if power is present, suspect and replace the cab headlamp and panel dimmer switch.
Conversation Summary
The owner of a 1999 GMC Sierra said the headlights stay on with the ignition on and that this is not the daytime running lights. The expert suspected a stuck headlamp relay or the always-hot headlamp switch. Replacing the relay with a known-good unit did not fix it, so the expert advised checking pin 85 for voltage and, if powered, suspecting the cab light switch.
