Hard starting Cadilliac
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Ask for diagnosis during the first-start condition and provide the technician with the overnight-versus-later-start pattern before authorizing a fuel-pump replacement.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
thanks
Darryl..
good luck
Darryl....
Discussion summary
A 1996 Eldorado required prolonged cranking for its first start of the day but started promptly afterward. The owner clarified that cranking speed was normal.
Reported outcome: No confirmed cause or successful repair was reported.
The reply discussed fuel-pressure loss, injector leakage and an older GM fuel-pump circuit as possibilities. None was tested or confirmed for this car.
