2000 Oldsmobile Intrigue Fan Only on High
GMC
89A677
I have a 2000 Oldsmobile Intrigue with 96,000 miles. The fan on AC/Heat only works on high. How can I replace the switch?
Mar 30, 2006 at 11:20 PM
LOSONE
  • 1,616 POSTS
The problem isn't the switch but the blower resistor pack that is located in the A/C and heater plenium. It is either directly behind the glove compartment or in the engine compartment mounted on the plastic A/C housing
Any parts store has one. Good Luck
Mar 31, 2006 at 12:39 AM
Suggested Repair
Replace the blower resistor pack in the A/C and heater plenum, either behind the glove compartment or on the plastic A/C housing in the engine compartment. Parts stores carry it; the fan switch is not the cause.
Conversation Summary
The owner of a 2000 Oldsmobile Intrigue with 96,000 miles says the AC and heat fan works only on high and asks how to replace the switch. The expert says the blower resistor pack is the problem, not the switch, and that it is in the A/C and heater plenum either behind the glove compartment or mounted on the plastic A/C housing in the engine compartment. Parts stores stock the resistor pack.
