Hello, I found a deal on a 99 Pontiac Grand Am SE for sale for only 500 bucks. According to the seller, there was a screaching noise under the hood and the engine stoped running and the starter wouldn't turn over. I tried jumping it with no luck, just the starter selenoid clicking. All the power stuff seems to come on. According to the seller, there were water problems, the radiator was replaced and her uncle believes that the water pump is shot. If the pump is seized, can this prevent the engine from cranking over? Is it possible, that the anti-theft system is preventing it from cranking? or the neutral safety?
Or maybe the starter went bad at the same time?
Besides the engine being seized or blown, what are some things to check out? This 99 Grand Am has the 2.4 liter, DOHC engine. Any words of wisdom is appreciated--Thanks-- mindstrap@gmail.com
May 5, 2006 at 2:28 AM
