1996 GMC Astro Fuel Pump No Prime
GMC
PAT
I have a 1996 Astro van AWD 4.3L. that quit running.
It seems like a fuel problem. When I listen in the gas tank and have someone turn ignition on I hear a single click. My question is each time the key is turned on should the electric fuel pump run for a second or so to pressure system.
Jan 24, 2006 at 4:57 AM
2CARPRO JACK
  • 11,533 POSTS
Yes the pump should run. When you replace the pump,you should also do the relay. Also inspect the wiring at the connector for the tank
Jan 24, 2006 at 8:28 AM
Suggested Repair
Replace the electric fuel pump and the fuel pump relay, and inspect the wiring at the tank connector. The pump should run briefly when the ignition is turned on to pressurize the system.
Conversation Summary
The owner of a 1996 Astro van AWD 4.3L reports that it quit running and suspects a fuel problem. They hear only a single click from the tank area when the ignition is turned on and ask whether the electric fuel pump should run briefly to pressurize the system. The expert confirms that the pump should run and advises replacing the relay along with the pump and inspecting the wiring at the tank connector.
